Hallo kurze Frage…
wo kauft ihr eure Bremsscheiben für den X-Bow ?!
werden die Bremsscheiben gegebenfalls auch bei anderen Autos (Audi, VW, Skoda ?) verbaut ?
Lg Lucky
Hallo kurze Frage…
Lg Lucky
Hat jemand die Dimension, Orginal Brembonummer oder Befestigungsloch-Abstand von den oem Sätteln ?!
Danke
Bonjour, pas de réponse à la question de Lucymaniac concernant les disques de freins ?
Die gibt es nur bei KTM.
Mark Murphy in the UK has original front disks for sale, and has also developed some very nice 2 piece ones. Go onto Facebook KTM X-Bow Fans
I have the following discs available;
standard front oem 305x22mm discs
floating 305x22mm vented race discs
foating 330x22mm vented race discs
Thanks
Mark Murphy
These are only available from KTM.
I have these discs on stock and also floating race discs in 305x22 & 330x22
The discs are specific to the KTM Xbow, there are no alternative direct fitment off the shelf from any other vehicle.
I have developed a floating brake discs with 305x22, standard fitment front (and upgrade fitment rear) and also a 330x22 option
Ihave available standard oem geuine KTM factory road discs is 305x22 if required.
Does anyone have the dimensions, original Brembo number or mounting hole distance from the OEM saddles?!
Thanks
