Hi - So XBow is not well today after one day at Spa.
There is a loud rattle coming from clutch area (goes away when clutch is pressed).
When driving in 1,2,3 gears there is a loud rattle/metallic sounds from the back of the car.
In 4th gear the sound becomes very loud.
The clutch doesn't have a smooth biting point anymore - the car suddenly lurches forward. Reverse the car was not happy - it kept 'getting stuck' once moving backwards.
I am thinking the problem could be: Bearing plate, Flywheel, or gearbox. Any similar experiences?
Also, any recommended garages to fix the car near Spa Francorchamps? I will be showing the car to RSR mechanic first thing in the morning but not sure if they will have time to fix.
Thanks
