is below the marked part VW AG on picture 3 ?
Beiträge von mac94
gut job
Ich sehe nicht die alte passat motorhalter
After some research im internet I have found
that the racing water pump on the powerpart catalog is an OEM water pump from BMWWe can found this on ebay for only 350$ and the powerparts it's 850 €
Was ist die normal temperatur ?
meine ist 92 wenn ich fahre langsam and 95 im autobahn 130km/h
Hello
I have always the engine light on after 15 minutes riding
and a few minutes later the light goes out*****************************************************************************************************************
obd code 160218010/P1602/005634 - Power Supply B+ Terminal 30: Voltage too Low
Possible Causes
- Cables on the Battery were removed
- Battery weak (voltage)
- Generator Disfunction
Possible Solutions- Check Battery Cables
- Check/Replace Battery
- Check/Replace Generator
Special Notes- If multiple Control Module have Power Supply Faults stored,
it's most likely to be one common Problem like the ones shown above.
Otherwise when only one or two Control Modules have such Codes stored
you better start searching at the individual Power Supply of these
Modules.
- Terminal 30 means unswitched battery power that is supplied
even when the ignition is off. This is not referring to any physical
terminal numbered 30.
I don't understand because the battery is new and cable are ok.
The alternator work fine I can read 14v on the obd reader programMaybe It's because of the emergency stop switch of the Clubsport..... It cut the power from the battery to the ecu and the ecu detect a disconnected battery
mit diese teile du musst die getriebe komplett demontiert fur installation ?
Bremsbeläge das is ok
hinter das ist die gleiche von meine mitsubishi evo 5
vorne das is gleiche focus rs 1, clio v6 etc..ich bestelle Bremsbeläge carbone lorraine RC5+ vorne No 4022 and hinter No 4060
Aber ich weiß nicht Brembo hergestellten Scheiben kunden nur für ktm denken.
Ich bin sicher, dass es mit einem anderen Auto kompatibel ist
golf 5 gti ist 312mm x 25 mm
ktm das ist 305 mm x 28 mm
wenn ich zu finden welche auto hat die gleiche Ich kann finden bremsen Ap racin oder dba oder performance friction
aber ich finde nicht im internet brembo disc mit 305 x 28 mm 5 x 112.
ok danke
haber welche auto hat gleiche bremsen ?
Die Bremsscheiben von den x-bow ist die gleiche von welche andere auto ? audi, vw ??????
Ich finde nicht im tarox site
Somebody have picture of the oil cooling system installing on the x-bow
who are connecting the oil hose who is the oil cooler and fan etc.....
Did you install an oil cooling ?
do you have some picture and information ?
thanks
I think the hose help a bit... many air come from the airbox and go directly to the top of the gearbox
I make a home made gearbox cooling for less than 10 euros
Alu Hose coming from the end of the originial airbox
hast du die carbon monocoque repariert ?
I mounted the new exhaust on the KTM. I had a very good price. Approximately one quarter of the new price.
I also removed the front plate support. I find pretty much like this
ja meine clubsport hat eine speerdifferential
The ktm battery is very difficult to access
I decide to make a charging system easy.
I order a Ctek charger MXS 5.0 and a comfort indicator pannel.
I found a good place to install the comfort panel... on the side of the heater.
Now It's very easy to connect the charger.... only plug into the pannel.
I can also insert a cig socker adaptator from ctek
Somebody know the diameter of the racing exhaust pipe ? The diameter of the tube ?
I will built myself an exhaust pipe.
Maybe 70 mm or 76mm
